Sonarr version (2.0.0.5163):
OS: Windows
Sonarr will not pass anything to my download client. If I do a manual search, every result says file is too big, maximum size is “15.0 MB” for every quality category even if the quality size is set to unlimited. The 15.0 MB never changes. Would a simple reinstall fix this or is there a better way to reset this issue?
Thanks
