Mapped network drive suppoort
Is there a way to point sonarr to networked drives?
I’ve done my research and I tried the UNC thing with //computername/mediafolder and it still didn’t work.
Plex can see them but sonarr can’t. Please help.
Have you read the FAQ? Either don’t run Sonarr as a service or use UNC paths (your slashes should be \ not /).
Do I just go to services and disable nzbdrone.exe and then create a shortcut to C:\ProgramData\NzbDrone\bin\NzbDrone.exe in startup?
Or do I not need to make any changes to services?
That will work.
You can remove the service completely via serviceUninstall.exe in C:\ProgramData\NzbDrone\bin\, but disabling it will have the same effect.
The service needs to be disabled or removed.
