Manually running task - Downloaded Episodes Scan
Every few times i manually run Downloaded Episodes Scan, it will hang, and hang, and hang. It doesnt give an error or anything, the refresh symbol just keeps spinning.
Right now my solution is to shutdown the service, and then start it.
Any idea’s?
Turn on trace logging and check the logs.
You shouldn’t need to run that task manually though, use manual import.
