Manually downloaded season packs are not imported automatically
Version:2.0.0.4753
Mono Version: 5.0.0
OS: unraid v6 docker (Linuxserver.IO)
((Debug logs)):
Description of issue: I’m not sure why is this happening, but when I manually download a season (through sonarr, so i search for an episode from a previous season, BTN returns the season pack, and i press manual download) it doesn’t get imported for some reason.
I download through deluge (not baclkhole), and after the download is finished, nothing happens.
Regular episodes get picked up automatically (RSSSync or IRC push).
If i use deluge and not blackhole, i can’t even specify folders, and sonarr should know the location through the deluge api anyway.
When I manually import it, it instantly recognizes the series, season and episode.
the first time it did this, i thought it’s just something to do with an unusual series name, but now i’m sure it’s something else.
It worked before, I’m not sure what i’ve changed.
I disabled drone factory, but it was a long time ago, and i’m not even sure what it is for.
any ideas?
I didn’t update deluge for sure, and sonarr is always running the latest version (in docker)
thanks!!
What do the logs show?
Does Sonarr show it in Activity: Queue?
I don’t see anything in the logs.
It just says that it was downloaded, sent to client, nothing after that, it showed up in activity (progress bar) I think, but after the fownload finished there was nothing there,i’m sure
and nothing was imported
The funny thing is, house of cards s5 was released yesterday, it was cought by rss sync as a season pack, it was downloaded and imported without issue.
now i’m testing another series (manual season pack download). IDK will it work or not, I’ll report back.
It shows up in activity/queue, hopefully it will import it
edit:
so, yeah, it imported it
i don’t know what changed, cos the previous 3 manual season packs were not imported…
maybe it’s a deluge filter setting, i don’t know, but i’ll def. keep an eye on it
btw i looked through the logs, and sonarr scans the disk every 12 hour for episodes in the series folder?
is this hdd activity so it spins the disk up? it seems pretty useless, a new episode would only get into sonarr, if it downloads it. what’s the logic behind it?
Files get deleted, renamed outside of Sonarr as well, this ensures Sonarr has a reasonably current view of the episodes on disk. It spins up the disk to get the list of files for each series and unless further processing is required that’s it.
