For filenames that don’t automatically come map correctly, I.E. “Episode 12 - Jolly Old St Dick.mkv” it would be really handy Instead of having to click the season select #2, then click the episode number and select the number rinse and repeat if you could instead type 2 press tab type 14 press tab then just cycle back and forth between the season/episode numbers going down.
If you select S01 and E01
it also makes no sense that when u map the next S01 E02 that S01 E01 is appearing again…
-select +map
