Magnet links + blackhole
Sonarr version (exact version): 2.0.0.4230
Mono version (if Sonarr is not running on Windows): 4.2.3 (Stable 4.2.3.4/832de4b Wed Mar 16 13:19:08 UTC 2016)
OS: Ubuntu Mate 16.04
((Debug logs)) (posted to hastebin or similar): http://pastebin.com/3V190ixS
Description of issue: Using the jackett fork that support public trackers, i added RARBG and Torrentz.eu to sonarr but when i try to use them i get error about magnet links not supported with blackhole. I just wanted to know if there was some sort of workaround ? i was searching the forum but didnt find anything.
No workaround at the moment, the only thing you can do is use a client that i supported in Sonarr instead of the blackhole.
alright so RARBG cant be used then…
