Lower quality being downloaded, higher already exist
I just noticed that drone grabbed all of Revolution Season 1 720p Bluray when I already have Bluray 1080p.
Is this because of how they named it: Re vol ution.2012.S01E01.Pilot.720p.BluRay.x264-DEMAND. If so, then shouldn’t drone not even recognize that file name?
Adding report [Rosemarys.Baby.S01E02.720p.WEB-DL.DD5.1.H.264-BS] to the queue.
Just noticed drone grabbed Rosemarys.Baby.S01E02.720p.WEB-DL.DD5.1.H.264-BS and I already have:
Rosemary’s.Baby.S01E02.Night.2.[WEBDL-1080p].mkv
Shedrock
A screenshot of the quality profile would be helpful (in edit mode).
Here it is:
http://postimg.org/image/696f3k7r3/
This is the only profile I use and this has never happened before.
Hmmm, profile looks fine, nothing has changed with how quality profiles work, so I’mnot sure how this could happen. Debug logs would be the next thing to help narrow this down.
I think this is saying that my current file is:
14-5-16 22:17:11.0|Debug|CutoffSpecification|Comparing file quality with report. Existing file is HDTV-720p
Which of course is not correct. Anyway, here is a link to the log:
What quality are those episodes shown at in the UI? Also a screenshot of the episode activity for one of those episodes would be nice to see, trying to get as much info as I can so I can try to reproduce it.
Hmm…I just noticed that they are all being displayed as HDTV-720p. I wonder why that is.
http://postimg.org/image/gse9lkpf3/
http://postimg.org/image/m2j8cv9nz/
Its a bug, the Bluray1080p is not parsing properly, its defaulting to the quality of mkv, which is HDTV 720p. I don’t see an issue with Rosemary's.Baby.S01E02.Night.2.[WEBDL-1080p].mkv though.
I’ll get a fix out for the 1080p parsing later on, at which time removing and re-adding the series should fix it.
Thank you for the fix.
As for Rosemary’s Baby, I have no clue why that happened. I did not even see anything in the logs for it.
Cheers!
I posted that I was still having the problem but these sorts of things happen when you don’t sleep. Anyway it all works well now.
Is there an easier way to update to show the proper quality?
I was just looking at most of my Bluray 1080p tv shows and I noticed almost all of them are showing hdtv-720p.
Thanks
drone doesn’t rescan files it already knows about, removing and re-adding the series would probably be the quickest way at this time.
Okay, Thanks.
