Hi, this just started today, sonarr’s home page shows nothing but the loading screen. It doesn’t show up from the computer it’s installed on, remotely from inside network or remotely from outside network. Also doesn’t show the main page in NZB360. It will however show the missing episodes while in NZB360. I’ve restarted computer and even installed a new copy over top of as of now and still no go. Windows 7.
Ok, I’ve uninstalled(backed up db backup files) and then re-installed.
Deleted everything, restored from backup and still no dice.
Are there errors in the log files?
Any errors in the Dev Console in your browser?
Which browser are you using?
Have you tried another browser?
Have you tried clearing your browser’s cache?
Does it load if you don’t restore your backup?
malformed database error, hence why i was reverting to an older db.
I tried deleting logs db first, that was a no go, so I backed up the backups and unstalled/deleted everything. Restoring from backup gives the same error…the backup was from almost a week ago and this problem started this morning.
Using chrome and nzb360, both don’t show the interface.
It loads fine if I don’t load my backup…rebuilding everything now.
This topic was automatically closed 59 days after the last reply. New replies are no longer allowed.
