Sonarr version : 10.0.0.24935 / Windows
The rename files task is stuck behind long running Check For Finished Download task and the download status is not updating.
Scenario is many downloads are complete, Check for Finished Download task needs to move all of the completed downloads to a remote PC which takes a long time.
Suggest the process of the Check For Finished Downloads task only check the status and queue the actual work for another process. The check task could then run every minute and the interface will still be updated with download progress.
I would also suggest allowing the Rename Files task to run while check for finished task is still running.
