Logs indicate error connecting to SAB
Was looking for Duck Dynasty s03e10. Found it on nzbindex.nl and downloaded it manually. Put it in nzbdrone download folder and it post processed it successfully. So then I looked at the logs to find out why it didn’t download it automatically. The logs indicate that it found an acceptable index on nzbindex.nl but then had trouble connecting to the SAB server. Any way to debug this further?
I dig the concept of nzbdrone and would like to help diagnose this issue. Cheers.
Check your SAB settings in NzbDrone and run a test, when configured correctly SAB will return its list of categories for you to choose from as well.
