Log Entry Questions and Missing Artwork
I’m finding some weird listings in my log file and was wondering if someone could help me out. I had to restore from a backup yesterday when everything got hosed from an update.
Two of my shows are missing the artwork and I see this in the log:
MediaCoverMapperFile /.config/NzbDrone/MediaCover/5/poster.jpg not found8
MediaCoverMapperFile /.config/NzbDrone/MediaCover/6/poster.jpg not found
Any way to reload them?
Also, it looks like Sonarr is making API calls for shows that are already downloaded.
8:40am - NzbSearchServiceSearching 1 indexers for [The Curse of Oak Island : S02E08]
I looked further back in the log and found this entry, so it knows that it already downloaded the file.
1:44am - [The.Curse.of.Oak.Island.S02E08.X.Marks.the.Spot.720p.HDTV.x264-DHD] Imported 1 files.
Thanks!
If the images are available on trakt they will be downloaded when the series is refreshed.
Sonarr doesn’t search for missing episodes automatically (https://github.com/Sonarr/Sonarr/wiki/FAQ#how-does-nzbdrone-find-episodes), nor for episodes with files unless the download failed. Without debug log files I couldn’t tell you why that search was logged.
