Listen on interface
Is there a way to make nzbdrone listen on a specific interface under linux?
Thanks!
You should be able to tell it which IP to listen on in the set up. I can’t check right now b/c of a bug that’s keeping mine down.
No there isn’t, by its on Trello: https://trello.com/c/aWazKGQc/404-allow-binding-to-specified-ip-address
