Currently, American Dad! on thexem.de is behind. It’s currently in Draft mode, correctly (public soon).
Anyway, I guess this could be considered a feature request. I’m sure it’s been discussed before but do you think it would be possible to add an option to download episodes (like sickbeard will do - based on naming) that don’t match and maybe dump them somewhere (at least these files could be deleted and/or moved manually to the drone import folder)? My biggest problem is if a show posts then gets trashed later, it may not be downloadable again.
We played with a similar idea before, it caused more issues than it solved and we don’t want to repeat that same mistake. An option only protects some users, lots will turn it on and it would be a support nightmare.
We have no plans to support alternate TV show data sources at this time, as long as thexem.de is kept up to date it rarely matters and since American Dad has been updated on thexem.de refreshing it should update Sonarr and it will be able to find it during searches.
