I set up sonarr and kodi together, everything is working fine. However when i download a tv show through sonarr, I get the notification on Kodi that it was downloaded but the library isn’t updated in Kodi. I’ve looked through the forums here and tried to find a solution but was unable to…
Looks like there is either an error or something unexpected coming back from Kodi, please pastebin trace logs of an import so we can see the response from Kodi.
And yes the kodi tv show library is empty because i cant seem to add anything from Sonarr, as it won’t update to Kodi. (there’s actually no tv show menu item yet since no tv shows have been added)
I know i can do a full scan of the drive (I don’t know how to do a folder scan) and it will add whatever tv shows \ video files to the “tv show” library… but i would like to find a solution so that Sonarr can do it automatically and update it in Kodi
The issue is the response that Kodi sends because the library is empty, with at least one series in Kodi’s library it will update properly, but in the current state Sonarr can’t.
I’ll get a fix out for the underlying issue into a future release though.
