So, I would prefer WebDL’s, as they have less of the network overlays. But I don’t want to miss anything.
Right now I use the 720p profile, with WebDL as the cut off.
Works ok, but I get a lot of duplicates as teh 720p comes out first, then a little later the webdl.
Is there any way, currently, to set a delay so that if 720 is available it marks it, but doesn’t send to get for X amount of time. Then if Web comes out, that gets sent and the 720 gets ignored?
If not, I can set a custom quality profile and make that work, but i’ll have to watch and see what shows consistently get webdl’s to be sure I don’t miss anything.
is there certain shows you get that release a Web-DL each week after the regular 720p if so you could simply set those shows to just look for Web-DL copies that way it will only grab them thus saving you from having to download an episode more than once
if there are shows that only sometimes come out with web-dl you could set Web-DL as the top quality to look for by dragging it to the top of the list it should search and prefer that over the standard HDTV release however i am not sure if for example it is set as Web-DL as the preferred quality but the HDTV is released first if it will still grab that and then replace later on when it see’s a Web-DL available
Thanks guys. I’ll add a vote to the trello card, and experiment.
