Keyboard shortcut: exit episode detail in calendar view
Hello!
Would it be possible to add a keyboard shortcut (Esc key) to exit the episode details in the calendar view (instead of having to click the “x”)?
See screenshot attached for details.
Thanks!
All modals should close when the Esc key is pressed, its all handled by Bootstrap.
Well… it’s not working for me… (tested on MacBook Air and Mac Mini, both Safari and Chrome) :disappointed_relieved:
Looks like it might be due to the modal not getting focus when its first opened, if you hit Esc after it opens without interacting with it it doesn’t work, if you click to focus the modal it works.
You’re right! Thanks, that will help.
