I have been using SickBeard/Rage for filling TV series and getting new episodes of TV series I’m following. I just noticed something I really DON’T like at all with Sonarr.
I downloaded an episode last night of one of the newly aired episodes, and Sonarr named it correctly and added the resolution to the name of the file as I set it up to do. Today, if found a higher resolution, which is good, as I keep several resolutions on hand already to support users of my Plex Media server streaming remotely.
Well, after this second download happened, it renamed the file, moved it into the folder that the series is kept in and then deleted the first version it downloaded last night.
This is NOT acceptable behavior. I want to keep the lower resolution for the remote users that stream from Plex to be streaming, and I want the higher resolutions for myself or anyone streaming locally to the server. How can this be done with Sonarr? It shouldn’t delete ANYTHING I don’t give it express permissions to delete, but still find the higher resolutions I’m looking for.
Do I need to set something else in the options to make sure this no longer happens? In some cases I have 2 or even 3 different resolutions of the same episodes. (1080, 480 and SD) I don’t want to lose several months of work getting all of these resolutions just to have Sonarr delete it all…
