KAT changed addresses
Hey is there any way to add custom torrent sites? Kickass was taken down today and is not up yet. Others need invites or logins. Any advice? I also cannot get eztv to work correctly. Thanks guy, awesome program will be donating soon!
kickass torrents have moved to kickass.to
ahhh nice thank you, I missed that
Is there away to update the address in Sonarr? Itā€™s still not finding any torrents.
When you click on the indexer tab in settings and select Kickass Torrents thereā€™s a website URL field you fill in. Make sure you type http://kickass.to I tested it and torrents are being picked up with this small change in the address.
Working perfectly! Thank you so much.
Yep thanks guys, any advice on getting eztv to work?
As far as Iā€™m aware EZTV RSS has been down for a few months now, and the devs over there wonā€™t give an ETA on when it will return. As far as I know you can only get EZTV to work when they fix the RSS issue. If anyone knows of another way, please share.
The test is failing when I enter this URL, error message ā€œUnable to connect to indexer, check the log for more detailsā€. Any ideas?
my log has the following exception
System.Xml.XmlException: ā€˜Content-Typeā€™ is an unexpected token. The expected token is ā€˜"ā€™ or ā€˜ā€™ā€™. Line 4, position 18.
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.Throw(String res, String[] args)
at System.Xml.XmlTextReaderImpl.ThrowUnexpectedToken(String expectedToken1, String expectedToken2)
at System.Xml.XmlTextReaderImpl.ParseAttributes()
at System.Xml.XmlTextReaderImpl.ParseElement()
at System.Xml.XmlTextReaderImpl.ParseElementContent()
at System.Xml.XmlTextReaderImpl.Read()
at System.Xml.Linq.XContainer.ReadContentFrom(XmlReader r)
at System.Xml.Linq.XContainer.ReadContentFrom(XmlReader r, LoadOptions o)
at System.Xml.Linq.XDocument.Load(XmlReader reader, LoadOptions options)
at NzbDrone.Core.Indexers.EzrssTorrentRssParser.PreProcess(IndexerResponse indexerResponse) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Indexers\EzrssTorrentRssParser.cs:line 22
at NzbDrone.Core.Indexers.KickassTorrents.KickassTorrentsRssParser.PreProcess(IndexerResponse indexerResponse) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Indexers\KickassTorrents\KickassTorrentsRssParser.cs:line 19
at NzbDrone.Core.Indexers.RssParser.ParseResponse(IndexerResponse indexerResponse) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Indexers\RssParser.cs:line 40
at NzbDrone.Core.Indexers.HttpIndexerBase1.FetchPage(IndexerRequest request, IParseIndexerResponse parser) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Indexers\HttpIndexerBase.cs:line 197
at NzbDrone.Core.Indexers.HttpIndexerBase1.TestConnection() in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Indexers\HttpIndexerBase.cs:line 211
https://kickass.to works fine for me
kickass.so is down, and kickass.to is blocked by my ISP (United Kingdom)
Is there a way to use a web proxy like : http://www.webproxy.net/view?q=kickass.to from within sonarr - as this would solve the country blocking problem
I tried using it via settings and testing the connection, but at the moment I get the error
Unable to connect to indexer: a name did not start with a legal character 38 (&) Line 34, position 91.
Kickass.to seems to work fine for me on BT? You could always use a VPN, the kickass.so domain was seized if you search the Whois records it says ā€œBANNEDā€.
Nope, kickass.to is blocked for me - Iā€™m stuck with talktalk (was nildram)
I get redirected here:
http://www.siteblocked.org/kat.html?accessurl=a2lja2Fzcy50bw==&urlclassname=S2lja0FzcyBUb3JyZW50cw==
Strange I am on BT and that URL is blocked.
Any body a member of the other invite only sites and fancy giving me an invite :smiley:
Iā€™m only a member with speed.cd - pity there is no support with sonarr
Oh well, back to buggy sickrage it is
This one worked for me! Also on BT and kickass.to was block!
http://kickass.hid.im/
Works a dream :smile:
Nice find :smile:
Works perfectly. Back to sonarr I go :slight_smile:
