Sonarr version: 2.0.0.5301 Mono Version: 5.18.0.240 OS: Raspbian Stretch Lite - November 2018 Debug logs: https://pastebin.com/23ayHSBv Description of issue: I’m running the linuxserver/sonarr docker container, along with separate containers for plex and deluge. Sonarr is able to grab torrents and send them to deluge, but they get stuck at 100% and aren’t processed or moved to the show folder as expected.
Interestingly, running the manual import does parse and process the episodes properly. I can’t seem to find any kind of failures concerning the automatic import in the logs, to my eyes it just seems to not be happening. Other steps I’ve tried include:
In Deluge? as in, it is at 100%, but is still in the downloading state rather than the seeding state? That is a Deluge issue, not a Sonarr issue. If you watch Deluge a lot, you will notice that it goes to 100% while it is still downloading pieces. Most likely there are a couple of pieces that it thought it had, but didn’t actually get flushed to disk, or that are just missing somehow. Easiest thing seems to be to force a recheck of that torrent. This will normally unstick it.
This should be 0 anyway. Drone factory is depreciated and will be removed from future versions.
Delue was actually showing the torrents as “Completed” for at least 10 minutes while Sonarr itself was stuck on the purple “100%” bar.
Being that it’s rPi and Docker though, I tried redoing my steps from scratch which took all of 45 minutes, and it does seem to work on this new instance. I can’t see anything I did differently, but I’m willing to chalk this up to pebkac
