OS: Windows 10 Pro
The Terror is listed in Sonarr with the name ‘The Terror (2018)’ however it is not named this (with the year) on any torrent sites so Sonarr is failing to download season two episodes because it is using the wrong search string (it is using the year 2018 in the title).
I further proved this by downloading an episode manually and then doing a manual important in Sonarr on the file and Sonarr says it is an unknown series, however when I add ‘(2018)’ in the filename and do a manual import again it recognises it and imports the episode.
I have made sure my indexers are working properly by doing the search for the terror from the indexer and it finds it fine, but when I use the search string sonar is using of course it doesn’t find it.
Search string sonarr is using (From Sonarr Log) = [The Terror (2018) : S02E04]
The correct search string would be = [The Terror : S02E04]
How can I get Sonarr to not have the year in the series title for this show or to use the correct search string?
