Issues with Series Specials
Version 2.0.0.5228
Mono Version 5.14.0.177
OS: Raspian Strech
Hey,
I’ve just started using sonarr a few weeks ago and still tweaking some of the settings.
Recently I’ve seen that the Specials of various TV Series are not identified properly and not downloaded. When I search them automatically I don’t get any downloads and when I search manually I get various errors:
Examples:
Vikings
Vikings.S03E00.Athelstans.Journal.WS.XviD-err0001 - [Permanent] Unable to parse episodes from release name
Vikings.Athelstans.Journal.2015.S03.E00.INTERNAL.720p.HDTV.x264.-FZHD - [Permanent] Unknown Series
Vikings.s03e11.Athelstans.Journal.WEB.Rus.Eng.AlexFilm.mkv - [Permanent] Unable to parse episodes from release name
My question is:
How can I force download those via Sonarr? I can download those rejected due to seeders or quality, but not this ones.
I know I can click on the link and go to that tracker, but I want this to go via Sonarr/Transmission/OSMC setup.
Any pointers?
Thanks
Specials are going to be a problem, either they’re labeled as being part of Season 1 or Sonarr will try to match based on the episode title, which is going to be a problem if the names are different enough.
In some cases you’re just going to need to download them manually.
