Sonarr version (exact version): 3.0.4.1066
OS: Windows 10
Debug logs: Debug
To be able to add shows when not connected to my home network, I have used port forwarding on my router to get to Sonarr. Recently, in the last couple of weeks, I can not longer connect outside of my network using my external IP. I can connect within the network using localhost and using the internal IP address. The same issue is also happening with Radarr. SABnzb seems to still work.
Have you run Sonarr as admin once?
Did your external IP change?
I ran it as an admin but no joy. External IP is the same.
Unless you’ve set a bindaddress there is nothing else that would block it. Make sure your firewall rules and network connection are set correctly; private and public networks have different Windows Firewall rules and other apps may be in both, but Sonarr isn’t.
yeah it seems like the firewall changed so I updated my port forwarding and it seems to work now thanks for the help
