Error code: [POST] Not Found : /api/queue/import
Sonarr Ver. 2.0.0.2493 develop
Debug log: http://pastebin.com/kQZZHkYe
Trace log: http://pastebin.com/pU9sKUjx
Description of issue: fetched a file via manual search and select of the appropriate nzb (not torrent; haven’t seen this issue with torrents). Nzbget fetched the file, downloaded it, unpacked, and it should have been sent to CDH. File is present on my NAS and can be manually played from remote PC by right clicking. File shows up in Plex and plays just fine.
Sonarr treats it in the following manner: the “downloading progress” purple bar never goes away unless you refresh the series. Refreshing the series shows the download as complete. The thumbnail and .nfo file are generated. Moving to another screen in Sonarr then does the following: in Calendar view, the fetched episode turns to red. In Activity, the item shows as downloaded with options to manually import or remove from history. In Wanted, the item shows up as still being wanted. Pressing “manually import” creates the above error.
