I feel I’ve got the hang of the software now after a couple of days, and I enjoy it very much.
But one minor issue has popped up recently with the show “Klondike”. Nzbdrone wasn’t able to grab an episode.
It’s a mini series and the releases are numbered with “part one” and so forth instead of “the usual” S01e01.
After searching my indexers by hand, nzbdrone only recognized a web-dl version that was tagged with s01e01 but none of the other hdtv releases that were tagged differently.
However, after manually downloading an episode with “part one” in the name and putting in into the drone factory folder, nzbdrone correctly identified, renamed and sorted the file.
My guess is this has probably something to do with the data provided by tvdb and trakt?
It has to do with the fact that Part One is not a supported numbering scheme, nor do we plan to support it. If it was Part 1 then it should be handled properly.
The only way it would import is if the filename has Part 1 or s01e01 in the filename. History will show the episode being imported and if you go to the details of it (the ‘i’ on the right side) it will show the original file name.
Wow, that was quick, thanks!
Pity, but not a big deal. And I just checked a couple of mini series: the naming scheme of the scene releases has usually been numeral (“part 1” instead of “part one”).
So here’s hoping Klondike was is just a “one-off”
The part about not wanting to support it is due to the fact its just a mini series, it will likely be done by the time we get to addressing it, if it becomes the norm we’ll re-consider our position, but its a lot of extra effort.
Indeed, we do hope its just this one.
