Issue searching for specific show
Sonarr version (exact version): 2.0.0.4753
Mono version (if Sonarr is not running on Windows):5.0.1.1
OS: Ubuntu 16.04.2 LTS
I am having an issue with searching for a specific show. The show is titled “Detective Conan”. I have Usenet and BTN API enabled. It will find episodes from the 25th Season, but most of the rest of the episodes from Season 1 to 24 are not found. They are on BTN, I have checked, here is an example of an episode name from Season 24, “[HorribleSubs] Detective Conan 763 [1080p].mkv”. I’m not sure that it’s a sonarr issue, but probably a BTN API issue, but I wanted to post here. I have the show set to anime mode as well.
The log is searching like this, “17-6-2 19:20:16.9|Info|NzbSearchService|Searching 1 indexers for [Detective Conan : 763]”, the episode is in a season pack as well.
((Debug logs)):
We need the debug logs to see what Sonarr is getting back from your indexers.
For newznab providers (not sure what usenet indexers you’re using) make sure the anime category is set, for BTN if there are only season packs you’ll want to do a season search.
Here are the debug logs
My last reply should get you on the right track since both those points seem to apply.
The problem is that I’ve added the BTN API to sonarr, and it’s not finding the season packs for this specific show. When I click on the episodes and search it’s finding nothing.
That’s relevant/important information for us to know.
It’s likely because of their season pack naming:
