It was working for about a month after initial setup and now I can’t get Sonarr to connect to qBitTorrent.
Getting this exception from the Sonarr logs:
NzbDrone.Core.Download.Clients.DownloadClientException: Failed to connect to qBitTorrent, please check your settings. ---> System.Net.WebException: Unable to connect to the remote server ---> System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it 127.0.0.1:21705
at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception)
at System.Net.HttpWebRequest.GetRequestStream(TransportContext& context)
at System.Net.HttpWebRequest.GetRequestStream()
at NzbDrone.Common.Http.Dispatchers.ManagedHttpDispatcher.GetResponse(HttpRequest request, CookieContainer cookies) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Common\Http\Dispatchers\ManagedHttpDispatcher.cs:line 53
at NzbDrone.Common.Http.Dispatchers.FallbackHttpDispatcher.GetResponse(HttpRequest request, CookieContainer cookies) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Common\Http\Dispatchers\FallbackHttpDispatcher.cs:line 60
at NzbDrone.Common.Http.HttpClient.Execute(HttpRequest request) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Common\Http\HttpClient.cs:line 70
at NzbDrone.Core.Download.Clients.QBittorrent.QBittorrentProxy.AuthenticateClient(HttpRequestBuilder requestBuilder, QBittorrentSettings settings, Boolean reauthenticate) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Download\Clients\QBittorrent\QBittorrentProxy.cs:line 214
at NzbDrone.Core.Download.Clients.QBittorrent.QBittorrentProxy.AuthenticateClient(HttpRequestBuilder requestBuilder, QBittorrentSettings settings, Boolean reauthenticate) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Download\Clients\QBittorrent\QBittorrentProxy.cs:line 228
at NzbDrone.Core.Download.Clients.QBittorrent.QBittorrentProxy.ProcessRequest[TResult](HttpRequestBuilder requestBuilder, QBittorrentSettings settings) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Download\Clients\QBittorrent\QBittorrentProxy.cs:line 156
at NzbDrone.Core.Download.Clients.QBittorrent.QBittorrentProxy.GetConfig(QBittorrentSettings settings) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Download\Clients\QBittorrent\QBittorrentProxy.cs:line 53
at NzbDrone.Core.Download.Clients.QBittorrent.QBittorrent.GetItems() in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Download\Clients\QBittorrent\QBittorrent.cs:line 83: Failed to connect to qBitTorrent, please check your settings.
When I browse to: 127.0.0.1:21705 I get the qBittorrent Web UI and use the same login/pw in Sonarr. I have checked the Windows firewall but since it is on the same machine it shouldn’t make a difference.
OS: Windows 10
Sonarr version: 2.0.0.4689
qBittorrent: 3.3.12 (64-bit)
