Is there another way to fix Unknown Series besides a manual download?
OS: UNRAID
Debug logs: See my question re: debug logs below.
When I go to manually download Ultraman, the episode shows a warning that the Episode is missing from the disk.
Clicking the Manual Search icon shows 2 episodes, both of which show a (Red !) with hover text that reads: Release Rejected: Unknown Series
There is no download icon next to the (Red !).
I’ve seen posts that say I need to download the series manually and rename it, but how do I do that if there is no download icon under Manual Search?
My full logs are here:
https://drive.google.com/open?id=16Ds5HaOq9H5MZbdgnyT8Cr5nF2nR73u2
The log that includes the Ultraman attempt is Sonarr2.txt
I have turned on debug logging and intend to post it as well but before I do that, how long should I run it, or what should I do to get the right info into the debug log before I send it?
From the Sonarr2.txt:
20-3-19 08:34:51.8|Info|AddSeriesService|Adding Series [73567][Ultraman] Path: [/tv/Ultraman]
20-3-19 08:34:51.8|Info|RefreshSeriesService|Updating Info for Ultraman
20-3-19 08:34:51.9|Warn|MediaCoverMapper|File /config/MediaCover/77/poster.jpg not found
20-3-19 08:34:52.1|Info|RefreshEpisodeService|Starting episode info refresh for: [73567][Ultraman]
20-3-19 08:34:52.9|Info|RefreshEpisodeService|Finished episode refresh for series: [73567][Ultraman].
20-3-19 08:34:53.0|Info|DiskScanService|Scanning disk for Ultraman
20-3-19 08:34:53.9|Info|DiskScanService|Completed scanning disk for Ultraman
20-3-19 08:34:53.9|Info|SeriesScannedHandler|[Ultraman] was recently added, performing post-add actions
20-3-19 08:34:55.2|Info|MediaCoverService|Downloading Fanart for [73567][Ultraman] https://artworks.thetvdb.com/banners/fanart/original/73567-18.jpg
20-3-19 08:34:56.0|Info|MediaCoverService|Downloading Banner for [73567][Ultraman] https://artworks.thetvdb.com/banners/graphical/73567-g.jpg
20-3-19 08:34:56.1|Info|MediaCoverService|Downloading Poster for [73567][Ultraman] https://artworks.thetvdb.com/banners/posters/73567-5.jpg
20-3-19 08:34:57.0|Info|MetadataService|Series folder does not exist, skipping metadata creation
You need to enable debug logging then post those,m info logs don’t have the release name.
