Sonarr version (exact version): 2.0.0.5153 OS: WIN10 Description of issue:
I have a very basic setup on just one PC. I was using it perfectly fine but recently my tracker made me change versions of Utorrent. I re-setup sonarr with UTorrent 2.2.1 and now it downloads everything fine and into the same directory as it was in before.
But after the download, it doesn’t process them and says “X is not a valid local path”
That version of uTorrent won’t work with Sonarr,
Seems you need at least v3(I asked the question last week why v2 couldn’t be used had 4 to do with the limited info the web client gives back to sonarr),
But that version is mostly banned.
So I use v2 for my bulk seeding(Season Seeding) and use qBittorrent with sonarr.
