Sonarr version (exact version): 2.0.0.5301 Mono version (if Sonarr is not running on Windows): 5.8.0.108-11 OS: Linux Synology DSM 6.2.1-23824 Update 4 Description of issue:
When I execute a manual search and from the result list I want to download a file that is identified as « rejected release », I cannot override this flag. Is there a way to do it. Thank you.
@padio: It is what @markus101 said. Sonnar can’t identify the series as the one you are searching for. Based on that picture I believe you did the reverse of the below. You are looking for the second series “Trapped (2015)” and that result is for “Trapped” the original or first series with that name (at least, as far as Sonarr can tell).
Thanks beardman your right.
The screen grab was showing the wrong title, but it was only to point out that the download button is not present to forcibly grab the file.
Here is another grab with the right file, but it is still not available to download.
click on the title, it will take you to the indexer site, download the torrent file, or copy the magnet link from there
when adding that to your download client set the final download directory to be the one youre using for sonarr downloads (typically its the category name) so that it sees it as one of its own
once its finished youll have to manually import if it cant work out which series its for though but thats not difficult, you may also have to cleanup the job in the download client
There are two shows title “Trapped” and one of them is a duplicate of the “correct” show “Trapped (2015)”
Try deleting the show and adding Trapped (2015) instead.
You could also try to get the duplicate removed from the TVDB. Or do what @rhom said. of course, you will probably have that problem every episode if you don’t have the correct show.
