Is it possible to change episode monitoring "options" after creation?
When I first add a new series, I can select a monitoring option, like Future, First Season, Latest Season, Missing. I get that after I add the series, I can adjust monitoring in the “Season Pass” section. The curious thing for me is that in the Season Pass section, I can toggle monitored status per season, or for the series. I’m trying to figure out how to either change the original monitoring option or to recreate it using the Season Pass settings.
Would it be accurate to say that “First Season” is the same as marking S01 ‘on’ and marking the series itself ‘off’? That was my guess, but I added a series with the “First Season” option, and the series was marked as monitored, so I’m not sure.
Season Pass or change it on the series details page.
The series needs to be monitored if you want any episodes in the series to be grabbed. Selecting First Season will monitor season 1 (and all its episodes) and the series and unmonitor the other series.
