I only noticed this error now, but the Web UI is practically unusable right now.
I use nzbDrone 2.0.0.1690. OS is Windows Server 2003 R2 32 bit; sabnzbd+ runs on the same machine.
I have used this combination for months without any problem.
Almost everything I do triggers an API error:
Doesn’t work:
- [GET] Internal Server Error : /api/episodefile?seriesId=1
- [GET] Internal Server Error : /api/notification
- [GET] Internal Server Error : /api/diskspace
- [GET] Internal Server Error : /api/update
- [GET] Internal Server Error : /api/system/backup?sort_by=time&order=desc
- [GET] Internal Server Error : /api/calendar?start=2014-08-03T22%3A00%3A00.000Z&end=2014-08-10T22%3A00%3A00.000Z
And maybe some other API-endpoints, these are some I noticed when clicking around in the web-UI.
Some /api-endpoints seem to work, but they don’t render on the screen.
When capturing the data in the F12-tools of the browser I notice this error in a json-object:
"message": "Index was outside the bounds of the array.",
"description": "System.IndexOutOfRangeException: Index was outside the bounds of the array.\r\n at System.Collections.Generic.HashSet`1.AddIfNotPresent(T value)\r\n at Microsoft.CSharp.RuntimeBinder.SymbolTable.AddNamespaceToSymbolTable(NamespaceOrAggregateSymbol parent, String sz)\r\n at Microsoft.CSharp.RuntimeBinder.SymbolTable.LoadSymbolsFromType(Type originalType)\r\n at Microsoft.CSharp.RuntimeBinder.SymbolTable.GetConstructedType(Type type, AggregateSymbol agg)\r\n at Microsoft.CSharp.RuntimeBinder.SymbolTable.LoadSymbolsFromType(Type originalType)\r\n at Microsoft.CSharp.RuntimeBinder.RuntimeBinder.<CreateArgumentArray>b__a(DynamicMetaObjectBinder p, CSharpArgumentInfo argInfo, Expression param, DynamicMetaObject arg, Int32 index)\r\n at Microsoft.CSharp.RuntimeBinder.RuntimeBinder.CreateArgumentArray(DynamicMetaObjectBinder payload, IEnumerable`1 parameters, DynamicMetaObject[] args)\r\n at Microsoft.CSharp.RuntimeBinder.RuntimeBinder.BindCore(DynamicMetaObjectBinder payload, IEnumerable`1 parameters, DynamicMetaObject[] args, DynamicMetaObject& deferredBinding)\r\n at Microsoft.CSharp.RuntimeBinder.RuntimeBinder.Bind(DynamicMetaObjectBinder payload, IEnumerable`1 parameters, DynamicMetaObject[] args, DynamicMetaObject& deferredBinding)\r\n at Microsoft.CSharp.RuntimeBinder.BinderHelper.Bind(DynamicMetaObjectBinder action, RuntimeBinder binder, IEnumerable`1 args, IEnumerable`1 arginfos, DynamicMetaObject onBindingError)\r\n at Microsoft.CSharp.RuntimeBinder.CSharpInvokeMemberBinder.FallbackInvokeMember(DynamicMetaObject target, DynamicMetaObject[] args, DynamicMetaObject errorSuggestion)\r\n at System.Dynamic.DynamicMetaObject.BindInvokeMember(InvokeMemberBinder binder, DynamicMetaObject[] args)\r\n at System.Dynamic.InvokeMemberBinder.Bind(DynamicMetaObject target, DynamicMetaObject[] args)\r\n at System.Dynamic.DynamicMetaObjectBinder.Bind(Object[] args, ReadOnlyCollection`1 parameters, LabelTarget returnLabel)\r\n at System.Runtime.CompilerServices.CallSiteBinder.BindCore[T](CallSite`1 site, Object[] args)\r\n at System.Dynamic.UpdateDelegates.UpdateAndExecuteVoid2[T0,T1](CallSite site, T0 arg0, T1 arg1)\r\n at CallSite.Target(Closure , CallSite , TaskCompletionSource`1 , Object )\r\n at Nancy.Routing.Route.<>c__DisplayClass4.<Wrap>b__3(Object parameters, CancellationToken context)"
It’s the same error I see in the logs.
I still get Pushbullet-notifications that stuff is being downloaded, so that part still seems to work.
Is there something I can try to investigate/fix this issue?
Thanks!
