Interesting errors and parse error
Added a series, it searched for and found some shows but failed to process. Sab has no errors, I have a folder with a bunch of mkv files 238235-0, 238235-0.1… etc they are clips, chapters, but no full video. Not sure what to do now, the whole season is queued but is stuck on this first episode. Activity page says “Single episode file contains all episodes in seasons” with yellow disk icon.
15-4-14 05:45:48.1|Info|SeriesService|Adding Series [277165][Silicon Valley] Path: [F:\New Shows\Silicon Valley]
15-4-14 05:45:48.6|Info|SceneMappingService|Updating Scene mappings
15-4-14 05:45:49.1|Warn|MediaCoverMapper|File C:\ProgramData\NzbDrone\MediaCover\38\poster.jpg not found
15-4-14 05:45:52.3|Info|RefreshSeriesService|Updating Info for Silicon Valley
15-4-14 05:45:52.7|Info|RefreshEpisodeService|Starting episode info refresh for: [277165][Silicon Valley]
15-4-14 05:45:52.8|Info|RefreshEpisodeService|Finished episode refresh for series: [277165][Silicon Valley].
15-4-14 05:45:52.9|Info|DiskScanService|Scanning disk for Silicon Valley
15-4-14 05:45:52.9|Info|SeriesScannedHandler|[Silicon Valley] was recently added, performing post-add actions
15-4-14 05:45:53.3|Info|MediaCoverService|Downloading Fanart for [277165][Silicon Valley] http://thetvdb.com/banners/fanart/original/277165-2.jpg
15-4-14 05:45:55.0|Info|MediaCoverService|Downloading Banner for [277165][Silicon Valley] http://thetvdb.com/banners/graphical/277165-g2.jpg
15-4-14 05:45:55.2|Info|MediaCoverService|Downloading Poster for [277165][Silicon Valley] http://thetvdb.com/banners/posters/277165-5.jpg
15-4-14 05:48:02.5|Info|RssSyncService|Starting RSS Sync
15-4-14 05:48:03.0|Error|Newznab|An error occurred while processing feed. https://api.nzb.su/api?t=tvsearch&cat=5030,5040&extended=1&apikey=<removed>&offset=0&limit=100
System.Xml.XmlException: Data at the root level is invalid. Line 1, position 1.
   at System.Xml.XmlTextReaderImpl.Throw(Exception e)
   at System.Xml.XmlTextReaderImpl.Throw(String res, String arg)
   at System.Xml.XmlTextReaderImpl.ParseRootLevelWhitespace()
   at System.Xml.XmlTextReaderImpl.ParseDocumentContent()
   at System.Xml.XmlTextReaderImpl.Read()
   at System.Xml.Linq.XDocument.Load(XmlReader reader, LoadOptions options)
   at System.Xml.Linq.XDocument.Parse(String text, LoadOptions options)
   at NzbDrone.Core.Indexers.Newznab.NewznabRssParser.PreProcess(IndexerResponse indexerResponse) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Indexers\Newznab\NewznabRssParser.cs:line 16
   at NzbDrone.Core.Indexers.RssParser.ParseResponse(IndexerResponse indexerResponse) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Indexers\RssParser.cs:line 40
   at NzbDrone.Core.Indexers.HttpIndexerBase`1.FetchPage(IndexerRequest request, IParseIndexerResponse parser) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Indexers\HttpIndexerBase.cs:line 197
   at NzbDrone.Core.Indexers.HttpIndexerBase`1.FetchReleases(IList`1 pageableRequests) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Indexers\HttpIndexerBase.cs:line 129
15-4-14 05:48:39.4|Info|DownloadDecisionMaker|Processing 298 reports
15-4-14 05:48:41.7|Info|RssSyncService|RSS Sync Completed. Reports found: 298, Reports grabbed: 0
15-4-14 05:50:58.5|Info|NzbSearchService|Searching 4 indexers for [Silicon Valley : S01]
15-4-14 05:50:59.1|Error|Newznab|An error occurred while processing feed. https://api.nzb.su/api?t=tvsearch&cat=5030,5040&extended=1&apikey=<removed>&offset=0&limit=100&rid=33759&season=1
15-4-14 05:51:15.3|Info|DownloadDecisionMaker|Processing 119 reports
15-4-14 05:54:13.9|Info|Sabnzbd|Adding report [Silicon.Valley.S01.1080p.BluRay.x264-ROVERS] to the queue.
15-4-14 05:54:19.8|Info|DownloadService|Report sent to download client. Silicon.Valley.S01.1080p.BluRay.x264-ROVERS
15-4-14 05:54:20.2|Info|SeasonSearchService|Season search completed. 1 reports downloaded.
15-4-14 06:04:05.0|Info|RssSyncService|Starting RSS Sync
15-4-14 06:04:05.8|Warn|HttpClient|HTTP Error - Res: [GET] https://api.nzb.su/api?t=tvsearch&cat=5030,5040&extended=1&apikey=<removed>&offset=0&limit=100 : 502.BadGateway
15-4-14 06:04:05.9|Warn|Newznab|NZB Su HTTP request failed: [502:BadGateway] [GET] at [https://api.nzb.su/api?t=tvsearch&cat=5030,5040&extended=1&apikey=<removed>&offset=0&limit=100]
15-4-14 06:04:32.3|Info|DownloadDecisionMaker|Processing 298 reports
15-4-14 06:04:34.5|Info|RssSyncService|RSS Sync Completed. Reports found: 298, Reports grabbed: 0
15-4-14 06:14:36.3|Info|SceneMappingService|Updating Scene mappings
15-4-14 06:19:36.8|Info|RssSyncService|Starting RSS Sync
15-4-14 06:19:37.4|Warn|HttpClient|HTTP Error - Res: [GET] https://api.nzb.su/api?t=tvsearch&cat=5030,5040&extended=1&apikey=<removed>&offset=0&limit=100 : 502.BadGateway
15-4-14 06:19:37.4|Warn|Newznab|NZB Su HTTP request failed: [502:BadGateway] [GET] at [https://api.nzb.su/api?t=tvsearch&cat=5030,5040&extended=1&apikey=<removed>&offset=0&limit=100]
15-4-14 06:20:14.8|Info|DownloadDecisionMaker|Processing 299 reports
15-4-14 06:20:17.0|Info|RssSyncService|RSS Sync Completed. Reports found: 299, Reports grabbed: 0
15-4-14 06:35:39.5|Info|RssSyncService|Starting RSS Sync
15-4-14 06:35:40.1|Warn|HttpClient|HTTP Error - Res: [GET] https://api.nzb.su/api?t=tvsearch&cat=5030,5040&extended=1&apikey=<removed>&offset=0&limit=100 : 502.BadGateway
15-4-14 06:35:40.2|Warn|Newznab|NZB Su HTTP request failed: [502:BadGateway] [GET] at [https://api.nzb.su/api?t=tvsearch&cat=5030,5040&extended=1&apikey=<removed>&offset=0&limit=100]
15-4-14 06:36:14.3|Info|DownloadDecisionMaker|Processing 299 reports
15-4-14 06:36:16.5|Info|RssSyncService|RSS Sync Completed. Reports found: 299, Reports grabbed: 0
15-4-14 06:43:12.0|Warn|DownloadedEpisodesImportService|Unable to parse file on import: [F:\Downloads\sonarr\Silicon.Valley.S01.1080p.BluRay.x264-ROVERS\238235-0.1.mkv]
15-4-14 06:44:42.1|Warn|DownloadedEpisodesImportService|Unable to parse file on import: [F:\Downloads\sonarr\Silicon.Valley.S01.1080p.BluRay.x264-ROVERS\238235-0.1.mkv]
15-4-14 06:46:12.2|Warn|DownloadedEpisodesImportService|Unable to parse file on import: [F:\Downloads\sonarr\Silicon.Valley.S01.1080p.BluRay.x264-ROVERS\238235-0.1.mkv]
15-4-14 06:47:42.6|Warn|DownloadedEpisodesImportService|Unable to parse file on import: [F:\Downloads\sonarr\Silicon.Valley.S01.1080p.BluRay.x264-ROVERS\238235-0.1.mkv]
15-4-14 06:49:13.6|Warn|DownloadedEpisodesImportService|Unable to parse file on import: [F:\Downloads\sonarr\Silicon.Valley.S01.1080p.BluRay.x264-ROVERS\238235-0.1.mkv]
15-4-14 06:50:43.2|Warn|DownloadedEpisodesImportService|Unable to parse file on import: [F:\Downloads\sonarr\Silicon.Valley.S01.1080p.BluRay.x264-ROVERS\238235-0.1.mkv]
15-4-14 06:51:42.3|Info|RssSyncService|Starting RSS Sync
removed and blacklisted nzb but keeps downloading them… 2GB each time, what a waste!
Blacklisting blocks the release name with an approximately matching date (3 days +/- at the moment), if there is another release outside of that window with the same name it wouldn’t be caught by Blacklisting.
You can use manual search to pick specific releases though.
In a manual search I noticed the release was blacklisted for the one indexer, not the others. Probably should identify the release some other way for the blacklist function to work as intended.
opps, we posted same time :wink:
