I’m Brazilian 28 years, I write using tranlater google, so I wrote this way.
The operating system on my laptop and windows, I do not use Linux.
Sonarr I want to install on my kodi that installed my raspberry.
Currently SickRage use but do not like, many bugs.
I do not think tutorial for those who do not use Linux.
Installed Sickrage trough a zip file (add-on).
I tried to find any zip file to install the sonarr, not found.
Can anyone help me?
As I already said, you do not have to install for those with windows.
To install on my kodi this installed on my raspberry.
The installation of Raspberry is only for linux users, I use windows.
Even tho there has been rumors that windows would or might run on rasp ( I have not seen it yet) I think you’ll find most installs are linux based and many are embedded and not easy to add this option it. You might be successful with a linux spin made for raspberry (raspian) and go that way, but it will be linux based.
