Installed update, issue with permissions
Sonarr version (exact version): Sonarr Ver. 2.0.0.4472
Mono version (if Sonarr is not running on Windows): Two versions Beta 4.6.2.7-8 and another version 4.2.1-0089
OS: Synology DSM 6.0-7321
((Debug logs)):
EventAggregator DiskScanService failed while processing [SeriesUpdatedEvent]: Access to the path “/volume1/SeriesEnded/The 100/Season 1” is denied.
Its driving me crazy, i had sonarr working flawless. Every update i first backed up any settings. Only last week the system updated all packages automatic. So i was not able to make a backup. After updating sonarr was put back to end 2015 regarding settings. All my series wherent up to date anymore.
I changed the settings and library to my best, i have two folders on different hard drives. My series on volume2 are updating without problems, however the series located on volume 1 dont update. It is possible a permissions issue, however i have not changed anything. I tried several things in the UI of Synology, without succes.
Any help is appreciated.
It took a while but finally found the solution. For some strange reason the user group sc media only had permissions on one folder, all the other folders not. Changing this did the trick
