Installation on Fedora 22
Hi, I am currently using SickRage but reading about Sonarr, I am curious to try it and if possible replace SR with it. But going through wiki, it seems installations is not as straight forward in Fedora as I would like. Has anyone tried it on Fedora?
Works great on my Fedora 22 system. I’m using the mono from https://copr.fedoraproject.org/coprs/tpokorra/mono/. Once I get around to updating my system to Fedora 23 I should be able to use the stock mono as Fedora 23 comes with mono 4.0.4.
Thanks for the reply. Fedora 23 is just around the corner. I will wait for the upgrade and then try it.
I’m running the beta of Fedora 23 on a wide variety of systems without any problems so there’s no need to wait for the final release. Updates from beta to final have always been painless for me.
