Hi!
I’m a relatively new user of your software, but after having sorted my libaray by hand for years I already love everything about it. As my library of tv shows is quite large, there’s still something I’m missing I had while sorting the library by hand, so I hope you will consider putting it in one of the next updates.
I currently have well over 1000 shows in my library and I’m looking for a way to sort the shows into subdirectories within the root directory. At the moment Sonarr puts all shows directly into the libary’s root so whenever I open that directory through cifs/smb there’s quite a bit of waiting time until I can see the content.
Please allow the series to be sorted into subdirectories. The initial character of the series’ names would be an ideal name for such subdirectories. Thereby one would have 26 sub-dirs [A-Z] wherein the actual series reside. Should be a minor patch to allow the “Series Folder Format” to be edited that way within the settings screen…
