Sonarr version (exact version): 2.0.0.4326
Mono version (if Sonarr is not running on Windows):4.2.2
OS: OS X 10.5.5
((Debug logs)) (posted to hastebin or similar): http://hastebin.com/uconixokih.md
Description of issue: Downloading from torrent trackers doesn’t work.
You logs don’t show any issues and I see RSS sync is finding results, just not anything you need (as nothing is grabbed). If you want to grab something that is on the missing list that wasn’t recently posted you can try searching.
Hi,
Ok, so here is the new message : Indexers unavailable due to failures: Rarbg
Indeed, nothing in the log.
Thanks
