Sonarr version (exact version): latest build
OS: windows server 2016
Description of issue: All 3 of my indexers are unavailable due to recent failures according to the debug log. Is there a way to override this ? I think it happened due to my VPN losing connection and shutting my VM down. All the indexers I have active are working fine.
You can’t prevent it, but Sonarr will continue to retry the indexer periodically. How long until the next retry depends on how many times it’s failed as it disables it starting at 5 minutes, up to 24 hours.
I’ve had this happen as well and it -seems- to me that when you do a manual test on an indexer it’ll also be available for Sonarr (iow earlier than whatever interval it currently is checking on) after the check - the test is not just for your peace of mind but for Sonarr’s functionality as well.
