Indexers are nor being connected
Two of my Indexers are nor being connected, I have checked both sights but the API’s are correct, contact with them says that the error is on my end ? My QNAP NAS and apps are fully updated.
Any help would be appreciated, thank you.
Sonarr 2.0.0.3953:
Mono version4.2.1.0:
QNAP TS-451:
Unable to connect to indexer: Curl Error 77 for Url https://api.nzbgeek.info/api?t=tvsearch&cat=5030,5040&extended=1&apikey=******************&offset=0&limit=100, issues with your operating system SSL Root Certificate Bundle (ca-bundle).
Unable to connect to indexer: Curl Error 77 for Url https://www.gingadaddy.com/api?t=tvsearch&cat=5030,5040&extended=1&apikey=******************=59006&offset=0&limit=100, issues with your operating system SSL Root Certificate Bundle (ca-bundle).
The CA bundle will need to be updated, this is outside of Sonarr’s control (it just makes use of it through cURL), you’ll likely have more success in asking how to do so on a QNAP specific forum.
Thanks Marcus I’ll do that.
I did the following despite having done it before.
Enabling SSL in Sonarr
Go to Settings -> General
Show advanced options
Enable SSL, set the SSL port
Save
Verify
One of the failed indexers reconnected but not the other one, weird !
