Indexer test succeeds, error when searching
Mono version (if Sonarr is not running on Windows): 4.6.2
OS: Rasbian
Debug logs: https://hastebin.com/hubolicexa.cs
When testing the Nyaa indexer from settings, it succeeds.
In the system tab it says “Indexers unavailable due to failures: Nyaa”
Specific error when searching is
Nyaa HTTP request failed: [400:BadRequest] [GET] at [https://nyaa.si/?page=rss&cats=1_37&filter=1&term=Gurren+Lagann+1]
HTTP Error - Res: [GET] https://nyaa.si/?page=rss&cats=1_37&filter=1&term=Gurren+Lagann+1: 400.BadRequest
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2 Final//EN">
<title>400 Bad Request</title>
<h1>Bad Request</h1>
<p>The browser (or proxy) sent a request that this server could not understand.</p>
As you see from the logs, I changed to the new nyaa.si domain. Did I miss something else I had to do for it to work?
Nyaa.si doesn’t support searching the same way that was done previously, not sure if they don’t support searching at all or they changed how it was done (which isn’t supported by Sonarr).
Thanks alot for replying!
Shame it doesn’t work out of the box. I’ll get it to work with Jackett I’m pretty sure :slight_smile:
