Sonarr version (exact version): Mono version (if Sonarr is not running on Windows): OS: ((Debug logs)) (posted to hastebin or similar): Description of issue:
now that kat is down I have tried to set up lime torrentz and a few others to no avail,
i have tried jacket install and setup using their api but also no sucess, is there some other indexer that is working ?
or help settipng up sonarr so that it downloads again
I am using RARBG. It seems to work OK but it is the only one that I have gotten to work.
Even closed sites like IPtorrents have issues in that many they can only be accessed via RSS feeds and I have not figured out how to avoid the junk the is all rar stuff on them.
But, as I said, RARBG is working fine for me so I guess the loss of Kat is not catastrophic. But I do miss it as it was easy and reliable.
Hey guys I hope I might find some helpe here, getting desperate I only recently discovered Sonarr and ist seemed too good to be true However, I cant set up indexers but none work except wombles.
I also signed up for TorrentLeech account, got RSS link and API as described on this forum, but can’t seem to get it working - just says check your settings. Any hints?
Thanks a zillion!
Tl has noob wait time until you can download, 48 hours for level 1 users. Read their new user guide it will explain how ratio works and how to build your buffer.
