Indexer catagories are not saved
Sonarr version (exact version): 4.0.15.2941
OS: Debian 12
Description of issue: Indexer catagories are not saved
I’ve just started using Sonarr, so this could very well because of a lack of indepth knowlegde; excuse my ignorance.
I use Prowlarr to add indexers to Sonarr, after which I configure their settings.
For example Ext Torrents. On initial setup the Catagories field is empty, Anime catagories contains TV/Anime. This config will not have it discover anything, so I added all TV related catagories to the Catagories field and click Save. It now find the items I am looking for. However, after a while this gets reset. How do I make the changes permanent? Some sort of setting, or is it Prowlarr that resets it? Any help is much appreciated :slight_smile:
Settings are saved until they’re overwritten, sounds like something (probably Prowlarr) is overwriting those settings.
It indeed was a Prowlarr setting. I forgot to set the Sync Categories
