Indexer always give invalid NZB
2.0.0.4230
4.4.1 (mono-4.4.0-branch-c7sr0/4747417 Mon Jun 20 15:43:48 EDT 2016
OS:
Mac OSX
NzbDrone.Core.Download.Clients.DownloadClientException: Failed to add nzb THE.LAST.MAN.ON.EARTH.(2015).S02E18.H.264.(WEB-DL).DD5.1.1080p.NLSubs.-Q.o.Q- English.nzb
at NzbDrone.Core.Download.Clients.Nzbget.Nzbget.AddFromNzbFile (NzbDrone.Core.Parser.Model.RemoteEpisode remoteEpisode, System.String filename, System.Byte[] fileContent) [0x0005b] in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\Nzbget\Nzbget.cs:44
at NzbDrone.Core.Download.UsenetClientBase1[TSettings].Download (NzbDrone.Core.Parser.Model.RemoteEpisode remoteEpisode) [0x0011f] in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\UsenetClientBase.cs:75 at NzbDrone.Core.Download.DownloadService.DownloadReport (NzbDrone.Core.Parser.Model.RemoteEpisode remoteEpisode) [0x00171] in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\DownloadService.cs:66 at NzbDrone.Core.Download.ProcessDownloadDecisions.ProcessDecisions (System.Collections.Generic.List1 decisions) [0x0014e] in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\ProcessDownloadDecisions.cs:74
Na matter which serie I try to DL there is always a NZB that is erroneous. The indexers Iuse are same as in Sickrage (worked there) and the test here is always OK.
So, were to look for a solution?
(Torrents work well.)
Make sure Sonarr can communicate with NZBGet properly, based on the snippet it looks that communication is failing, but without the full context its impossible to say why.
