Increase maximum quality size
In the “Quality Definitions” the max i can only set it 12.58 GB is there a way to set this higher? Only ask as a recent episode was 15GB and was missed by Sonarr
Set it to 0 for unlimited.
What quality was 15GB?
It was HDTV 1080p
Setting it to unlimited means i cant set a minimum
Please tell me: Which release was that good?
It was Penny Dreadful S02E03 1080p HDTV X264-DIMENSION
DIMENSION has been releasing those 1080p at large sizes yes, 10 GB+ and such. BATV, DIMENSION vs the rest trying to prove better quality by encoding the source at same quality.
@markus101 we could put max as unlimited without breaking much.
It’s been slowly getting bigger and bigger files sizes, Penny Dreadful alone has gone from 5Gb for the first episode to 8.8Gb for the second and now this 15Gb for the third
Just wanted to say thanks for increasing the file size :smile:
You’re welcome. although I didn’t really increase it, just changed the way you configure unlimited :smiley:
