Importing deletes files in destination location
OS: Windows 10
Debug logs: https://pastebin.com/ijM7Jbvn
I’m using sonarr with uTorrent. I’m not sure if I’m setting up directories correctly this is all new to me. However, sonarr is able to download torrents via uTorrent, but won’t automatically import them, it seems to always fail, and then when I manually import them via the button it seems to work. When another torrent starts downloading however, all the imported files get deleted. It looks like it’s using hardlinks instead of copying even though I disabled it. Recently it’s not even placing the files in the correct folder and seems to be doing it’s own thing.
18-4-6 12:42:03.4|Warn|ImportApprovedEpisodes|Couldn't import episode C:\Users\elanm\Downloads\Completed Torrents\The.Expanse.S01E02.1080p.WEB-DL.DD5.1.H264-RARBG\The.Expanse.S01E02.1080p.WEB-DL.DD5.1.H264-RARBG.mkv
[v2.0.0.5163] System.IO.IOException: The specified network name is no longer available.
Make sure you have read the FAQ entry on mapped network drives.
Hardlinks don’t work across volumes, but Sonarr will do hardlinking to create a duplicate file in some cases.
