Hi, I’m getting a few of these errors.
I might have moved the files while it was trying to import them (not smart, I know)
Is this debug info sufficient ?
Message
Couldn't import episode /media/Data/Downloads/tv/breaking.bad.s05e16.mkv: Invalid handle to path ""
Exception
System.IO.IOException: Invalid handle to path ""
at System.IO.File.Move (System.String sourceFileName, System.String destFileName) [0x00000] in <filename unknown>:0
at NzbDrone.Common.Disk.DiskProviderBase.MoveFile (System.String source, System.String destination, Boolean overwrite) [0x000d0] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Disk\DiskProviderBase.cs:210
at NzbDrone.Common.Disk.DiskTransferService.TryMoveFile (System.String sourcePath, System.String targetPath) [0x0009b] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Disk\DiskTransferService.cs:394
at NzbDrone.Common.Disk.DiskTransferService.TransferFile (System.String sourcePath, System.String targetPath, TransferMode mode, Boolean overwrite, Boolean verified) [0x002b5] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Disk\DiskTransferService.cs:162
at NzbDrone.Core.MediaFiles.EpisodeFileMovingService.TransferFile (NzbDrone.Core.MediaFiles.EpisodeFile episodeFile, NzbDrone.Core.Tv.Series series, System.Collections.Generic.List`1 episodes, System.String destinationFilePath, TransferMode mode) [0x0010e] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\MediaFiles\EpisodeFileMovingService.cs:118
at NzbDrone.Core.MediaFiles.EpisodeFileMovingService.MoveEpisodeFile (NzbDrone.Core.MediaFiles.EpisodeFile episodeFile, NzbDrone.Core.Parser.Model.LocalEpisode localEpisode) [0x0005e] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\MediaFiles\EpisodeFileMovingService.cs:80
at NzbDrone.Core.MediaFiles.UpgradeMediaFileService.UpgradeEpisodeFile (NzbDrone.Core.MediaFiles.EpisodeFile episodeFile, NzbDrone.Core.Parser.Model.LocalEpisode localEpisode, Boolean copyOnly) [0x00119] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\MediaFiles\UpgradeMediaFileService.cs:64
at NzbDrone.Core.MediaFiles.EpisodeImport.ImportApprovedEpisodes.Import (System.Collections.Generic.List`1 decisions, Boolean newDownload, NzbDrone.Core.Download.DownloadClientItem downloadClientItem) [0x0024e] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\MediaFiles\EpisodeImport\ImportApprovedEpisodes.cs:90
Thanks !
edit: I had a look at the trace log level, it parses the file fine but just doesn’t move/rename it because of this mono error.
