I have downloaded some files that are totally numbered incorrectly (futurama) it would seem the uploader has numbered them in order of broadcast date, and not dvd release date.
Looking in Sonarr the file names have the correct episode but the incorrect season and episode numbers, will sonarr import these correctly, or should i remove the season and episode tags?
Tesh
Sonarr uses thexem to convert scene numbering (usually following broadcast “seasons”) to dvd numbering.
See http://thexem.de/xem/show/956
So if you have a download labeled as S02E06, sonarr will import it as S02E11 for example.
Its not broadcast to DVD ordering, but “scene” to tvdb, the scene often starts a new season or continues an old one when releasing episodes, but tvdb follows the broadcasting season/episode numbering so they conflict.
Sonarr doesn’t support DVD ordering and also expects episodes in your series folder to be sorted via tvdb numbering, but will import from “scene” numbered episodes and translate them.
Right so i fixed this issue thankfully - however whats going on here why is the progress bar yellow? none of my other shows are.
http://www. 28greenlane.co.uk/pic_share/c588884eb9106cd.JPG
Look at the bottom of the series page for a legend of the colours and their meanings.
