Import issue on failed downloads
Hi,
previously with my sonar set up I didn’t have it sort out my shows as I wanted them all in one main folder which I would watch then delete.
I’ve now moved over to Plex front end and would like to turn the folder sorting feature on.
I seem to have a problem with failed deliveries, sonarr is taking the download files and moving them into the correct folders, yet for ones that fail on repair I just see a purple bar saying 100% downloaded.
below is the log starting from the point where I asked it to search for a series
Ive upload the log to my onedrive account and given shared access (I didn’t know how best to do it)
http://1drv.ms/1WB4ucQ
any help would be much appreciated
use hastebin to post logs.
also, make sure sorting is not enabled in Sab.
Sorry how do I do that on an iPad
It all ran through Nzbget the downloads failed and they were stuck in the activity when I clear it they show they ar needed.
I just would like to know the cause and to prevent it
