Sonarr version (exact version): 2.0.0.5344 Mono version (if Sonarr is not running on Windows): 5.10.1.57 OS: FreeNAS 11.3-U1 Debug logs:
Import failed, path does not exist or is not accessible by Sonarr: /media/downloads/Chopped.S45E06.Just.Desserts.Celebrities.720p.WEBRip.x264-LiGATE[rarbg]
In the Unix file path, to compensate for the ‘[’ character, there is an escape character ‘backslash’ which is added so what Sonarr is looking for doesn’t account for the escape character ‘’. As a result, Sonarr perceives a failed path and perceives no file. But the file does exist on a slightly different path reported by the OS.
What the host OS in the Sonarr jail sees:
ls /media/downloads/Chopped.S45E06.Just.Desserts.Celebrities.720p.WEBRip.x264-LiGATE\[rarbg]/ Chopped.S45E06.Just.Desserts.Celebrities.720p.WEBRip.x264-LiGATE.mkv
OK, I’m having to hand edit the above because the forum page keeps removing the ‘backslash’. In between LiGATE and [rarbg] is a backslash character in the unix path name as shown in the included graphic.
Close
Thanks for the note. Client is qBittorrent v4.1.9.1
I was going to look at the changes for 2.0.0.5344 - Mar 13 2020 (pushed out in the last couple of weeks), but the github release page doesn’t have the last 2 bugfix releases:
So, this turned out to be a path issue. In a previous jail-based Sonarr, both Sonarr and Qbittorrent shared a physical host. I have since moved Sonarr into a docker container.
So, in Sonarr, Settings::Download Client::Remote Path Mappings, the remote host with Qbittorrent, the Qbittorrent remote path (e.g. /media/downloads/) and the local Sonarr path (e.g. /downloads/) in the docker container need to be mapped out. With this additional information, Sonarr is able to resolve the paths between the two hosts as they were slightly different.
