Import failed error - not sure how to fix
OS: Windows 7
Debug logs: https://pastebin.com/mUyeraJ8
Description of issue: Sonarr isn’t moving files after download, nor can I use the manual import function either, but I think I know why but I can’t fix it. I see in the error logs that Sonarr thinks the files are in a folder with the same name, i.e. Family.Guy.S16E13.1080p.WEB.x264-TBS.mkv is a folder with the same name, C:\Media\Sonarr Temp\Family.Guy.S16E13.1080p.WEB.x264-TBS – I assume this might be an issue with qBittorrent because if I look at the downloads, the file name for this file is Family.Guy.S16E13.1080p.WEB.x264-TBS not with a .mkv. I am not sure how to resolve this in qBittorrent either. The “Create subfolder for torrents with multiple files” option is not checked, is this the problem? I made a folder called “Family.Guy.S16E13.1080p.WEB.x264-TBS” within the downloads folder and then the file appeared when I tried to manually import it in Sonarr. I’m super confused.
I believe so, have you tried enabling it?
